Hi Michel
In the meanwhile i have made some changes to your model and now it
loads in repository 6, i think you will still be able to use it. The
new model has been uploaded to the file section as recumbentv2.zip
I have changed a lot of stuff, please try to search for AnyBody
support to find the locations. Some changes i did not add comments
on, these are typical syntax changes like Axes are changed to Axes0
and r chnaged to r0. Further more in the
jointAndDriversSupport2.any file i have similarly made syntax
changes on the Reaction.Type setteings in the drivers.
The following files have been changed as i recall it:
DrawSettings.any : added a marker folder which the new brep use
JointAndDriverSupport2.any: numerus changes on syntax and changes
in the fourierdriver on the pedals.
Bikemodel.main.any: Changes in the model anyfamily member since i
did not have the used file, saddelpos was changed accordingly.
Calibration statement was changed so the only the legs are calibrate
not the fullbody which is not there.
BikeWheelAndFrames.any : some minor synatx changes of Axes and r.
AnyBody Support
— In anyscript@yahoogroups.com, “sybert84” <sybert84@…> wrote:
> Hi Soren,
> I’ve changed some directory’s and repository’s, and
> now it is working. I don’t really know what I’ve have
> done, but it is working right now.
> Thanks for your time!
> Kind regards,
> Michel
> wrote:
> > Hi Michel
> > Please try to zip your recumbent bike direcertory and upload it
to
> > the file section of the group then we will try to debug the
model.
> > Best regards
> > AnyBody Support
> > — In anyscript@yahoogroups.com, “sybert84” <sybert84@> wrote:
> > > Hi,
> > > I compared my calibration part with that from the BikeModel3D
> and
> > I
> > > didn’t see differences between those. I copied my part below,
> > maybe
> > > you can see what is wrong with it.
> > > //This calibration sequence will calibrate the legs only
> > > AnyFolder &HumanFolderRef= Main.Model.HumanModel; //This is
> the
> > > reference to
> > > //the folder which contains the human model
#include “…\BRep\Aalborg\BodyModels\FullBodyModel\CalibrationS
> > > equence.any”
> > > The part where something is wrong in it, is the following:
> > > AnyOperationSequence CalibrationSequence ={
> > > AnyOperation
&Cal1Right=.RightLegCalibration1.LegCalibrationStudy1.MuscleCalibrati
> > > onAnalysis;
> > > AnyOperation
&Cal1Left=.LeftLegCalibration1.LegCalibrationStudy1.MuscleCalibration
> > > Analysis;
> > > AnyOperation
&Cal2Right=.RightLegCalibration2.LegCalibrationStudy2.MuscleCalibrati
> > > onAnalysis;
> > > AnyOperation
&Cal2Left=.LeftLegCalibration2.LegCalibrationStudy2.MuscleCalibration
> > > Analysis;
> > > AnyOperation
&Cal3Right=.RightLegCalibration3.LegCalibrationStudy3.MuscleCalibrati
> > > onAnalysis;
> > > AnyOperation
&Cal3Left=.LeftLegCalibration3.LegCalibrationStudy3.MuscleCalibration
> > > Analysis
> > > I sorry to bother you with this, but I really don’t know what
to
> > do
> > > anymore. Thanks for all the help.
> > > Kind regards,
> > > Michel
> > > wrote:
> > > > Hi Michel
> > > > Ok i think this is because the calibration studies in the
Brep
> > has
> > > > changed in the way they are being included into the model.
> > > > Please look in the main files of for example the bikemodel3d
> > model
> > > > in the arep/aalborg directory of rep. 6. Then copy the
section
> > for
> > > > the calibration and replace it with the calibration
definition
> > you
> > > > have in your current main file.
> > > > Best regards
> > > > Søren, AnyBody Support
wrote:
> > > > > Thanks for the quick reaction, but
> > > > > I copied the files in the repository.6 directory
> > > > > which I downloaded. But I still have a problem with
> > > > > loading. The same error message appears. Besides
> > > > > the recumbent directory, which i placed in the new
> > > > > map, i copied the files in de brep to the new directory.
> > > > > When I removed one dot for Sign, i got a new error message:
> > > > > ERROR(SCR.PRS9) : E:\michel\Repository\Repository.6
> \BRep\Aalborg\BodyModels\FullBodyModel\CalibrationSequence.any
> > > > > (51) : ‘Cal1Right’ : Unresolved object
> > > > > There is something wrong in this line:
> > > > > AnyOperation
> > > > > onAnalysis;
> > > > > Kind regards,
> > > > > Michel
> <support@>
> > > > > wrote:
> > > > > > Hi Michel
> > > > > > Welcome to the group.
> > > > > > I think your problems are related to that you are trying
> to
> > > run
> > > > > > repository 5 on a AnyBody Ver. 2?
> > > > > > There are some minor syntax changes between AnyBody
ver.1
> > and
> > > > > ver.2,
> > > > > > and the error you get and the description fits with
that.
> So
> > > > > maybee
> > > > > > Kenneth was running an old version of AnyBody and you
are
> > > > running
> > > > > > the newest one, this can be seen in the About box in the
> > Help
> > > > menu.
> > > > > > There are two ways to resolve the problem.
> > > > > > 1 you could download the newest version of the
repository
> > > ver.6
> > > > > from
> > > > > > www.anybody.aau.dk and insert your recumbent bike into
the
> > > arep
> > > > > > folder, this will have the benefit of updating the
> > repository
> > > > with
> > > > > > bug fixed etc.
> > > > > > 2 you could keep your current model and update the
syntax
> to
> > > > work
> > > > > > with the new version.
> > > > > > There are mainly two things you need to change if you do
> the
> > > > > latter.
> > > > > > In all segments “r” and “Axes” is now “r0” and “Axes0”
> > > > > respecetively.
> > > > > > If you double click on the error message you get you
will
> > jump
> > > > to
> > > > > > the file mus.any and the line looking something like
> > > > > > SPLine.InitWrapPosVectors = {
> > > > > > {0.04,0.03,0.0*…Sign}, {0.1,…Sign0.0,0.0}
> > > > > > please remove one dot in front of the “Sign” variables,
so
> > > that
> > > > it
> > > > > > will look like
> > > > > > {0.04,0.03,0.0…Sign}, {0.1,…Sign*0.0,0.0}
> > > > > > Why it is like this is a long explanation so i have
> copied
> > it
> > > > > from
> > > > > > the official release notes:
> > > > > > Important notice: Scope for right-hand side variables
have
> > > > changed
> > > > > > to be the scope of the assignment instead of the scope
of
> > the
> > > > > > variable to be assigned. This typically does not mean
> > > anything,
> > > > > but
> > > > > > for complex assignments like Folder1.var1=…var2; it
> implies
> > a
> > > > > > change. It will now be Folder1.var1=.var2; (only 1 dot
> > before
> > > > > var2)
> > > > > > because it is not relatively to the scope of the
> expression
> > > and
> > > > > not
> > > > > > the scope of Folder1 that is used for the right-hand
side
> > > > > evaluation.
> > > > > > You can read the full version of the release notes of
ver.
> 2
> > > > > > on this page http://www.anybodytech.com/466.0.html
> > > > > > I hope this helps you move on, otherwise please do not
> > > hesitate
> > > > to
> > > > > > write again.
> > > > > > Best regards
> > wrote:
> > > > > > > Hi Soren,
> > > > > > > I have a problem with loading of an AnyBody model. The
> > model
> > > I
> > > > > was
> > > > > > > using gave a Error message:
> > > > > > > Model loading skipped
> > > > > > > Loading
> > > > Main : “E:\pamela\pamela\model\Repository\Repository.5
> > > > > > > \ARep\Aalborg\Recumbent\BikeModel.main.any”
> > > > > > > Scanning…
> > > > > > > Parsing…
> > > > > > > Constructing model tree…
> > > > > > > ERROR(SCR.PRS9) :
> > > > > > > \BRep\Aalborg\Leg3D\Mus.any(216) : ‘Sign’ :
> > Unresolved
> > > > > object
> > > > > > > Deleting last loaded model…Done.
> > > > > > > My supervisor (Kenneth Meijer, University Maastricht)
> had
> > a
> > > > back-
> > > > > > up
> > > > > > > of the model on his computer. The loading
> > > > > > > of this model went okay. Now we copied the back up to
my
> > > > > computer
> > > > > > > and tried to load the “new” model.
> > > > > > > The same Error message appeared during loading of the
> > model:
> > > > > > > Loading Main : “E:\pamela\pamela\model
> > > > > > > pamela\Repository\Repository.5
> > > > > > > Scanning…
> > > > > > > Parsing…
> > > > > > > ERROR(SCR.PRS9) : E:\pamela\pamela\model
> > > > > > > (216) : ‘Sign’ : Unresolved object
> > > > > > > I really don’t know what is wrong with this, because
it
> > work
> > > > > well
> > > > > > on
> > > > > > > Kenneth’s computer. Can you
> > > > > > > help me with this?
> > > > > > > Kind regards,
> > > > > > > Michel van Exsel
> > > > > > > The Netherlands
