I previously completed the wrapping muscles tutorial and went back to this model to learn more about wrapping muscles.
I tried to replace the cylindrical surface with a sphere using the following code:
AnyRefNode CylCenter = {
sRel = {0, 0, 0};
//ARel = RotMat(20*pi/180,y);
AnySurfEllipsoid WrapSurf = {
Radius = {0.15, 0.15, 0.15};
//Length = 0.4;
AnyDrawParamSurf drv = {};
//CapRatio = 0.100000;
This code seemed to work BUT muscle 2 for which InitWrapPosVectors were set to make the muscle wrap under the object wrapped over the object.
I modified to origin and insertion points for this muscle so that they were on the xy plane (i.e. set z to zero) to see if this was the problem. When I did this I got the following error:
ERROR(OBJ.LIB.OOS1) : E:/AnyBody_Monique/Demos/MuscleDemo.4.any : Muscle2.SPLine : Unexpected exception in the library OOSol :
OOSol exception : MISSING MESSAGE.
This error is the same as I was experiencing with my own model. Maybe there is lack of understanding on my part on how the ellipsoid surfaces work. Could you please help me with this problem.
Thanks
Monique
