Run kinematic error at time step 171
I can’t run kinematic to complete.
I don’t what a problem occur.
I attach a file.
If the model runs until step 171 and then fails kinematically it can be related a marker dropping out (then the it goes back to 0,0,0) this may make the model fail.
Please inspect the trajectory data to ensure you have no drop out markers in the data.
If you do not have marker drop out please inspect the motion you do get until step 171 and try move markers closer to the positions they were place on the subject, while doing the experiment.
I try to solve follow your suggest but I can’t do it. How can I fix it?
