AnyBody Console Application
AnyBodyCon.exe version : 4. 2. 1. 1614
Build : 14788.27660
Copyright (c) 1999 - 2011 AnyBody Technology A/S
Warning : Program argument '-' was not recognized !
Error : Wrong directory specification in program arguments (--dir='U:\Shoulder' is not a valid directory)
USAGE :
AnyBodyCon.exe <arguments>
AnyBodyCon.exe MacroFile.anymcr <arguments>
ARGUMENTS :
/?, -?, --help
Help
/d <dirname>, -d <dirname>, --dir=<dirname>
Sets current directory to 'dirname'.
/m <macrofile>, -m <macrofile>, --macro=<macrofile>
Specifies the macro file to execute to 'macrofile'.
the problem is that you have a space in your file paths. When you supply an argument to an executable in the command line mode - it is read until the first space and will look in your case as “U:\Shoulder”. To avoid that - please use double quotes around the file path (letting the program know that this is still the same argument), like the following:
“U:\Shoulder model\Diploma thesis\AMMRV1.0 - 110104\Application\Examples\StandingModel - Kopie\StandingModel.main”
