Hello, I made such a mistake when I was doing reverse dynamics analysis. Muscle recruitment solver : solver aborted after maximum number of iterations.What should be adjusted for this problem? Thanks!
Hi Yu,
Basically it means the model lacks ability to create balance in the model.
If you are using a human model from AMMR it usually means you did not provide support/reactions to the environment. If you are building your own model it can also be that certain DOF in the model do not have enough muscles around it.
Please see this wiki page https://github.com/AnyBody/support/wiki/Model-trouble-shooting#make-the-solution-of-the-inverse-problem-stable
