Sum of forces not equal to zero
Hi all
So I am working with the shoulder model and trying to reduce the 20 muscle forces to one resultant force.
However, when I export all the forces (muscle and joint/ligament reaction forces) and add the components together, it is not zero; which actually should be, assuming quasi static conditions for the inverse dynamics, right? :confused:
Can someone tell me why it is? I am pretty sure my calculations are right.
Thank you!
Best, Seline
Hi Seline,
No, it should sum up to the inertial forces. It should be a perfect 0 for a static posture - please try.
