I imported the C3D file in Anybody. When I added two markers,I found that the location of the C3D marker is wrong. What should I do? Thank you for your help.
BW
zzs
Hi zzs,
The only way i can explain this picture would be if your firstframeno is much later than the in the mokka picture displayed, this could explain the difference… the FirstFrame can be set in the TrialSpecific file.
Hi Søren
Thank you for your reply,I have solved this problem. I have some errors when I run the inverse dynamics analysis. Can you tell me what to do?
zzs
Hi Zzs,
This warning means that the muscle insertation or origin point is pushed inside one of the objects is it supposed to wrap around.
The reasons is typically wrong scaling…. physical impossible motions
Hi Søren
Thank you for your quick reply, but I don't know how to solve it
Will this warning affect the results of the analysis? Can you tell me what should I do.
zzs
Hi Zzs,
This error can occur at load time or while the analysis is running.
If the error is only when the model is loaded then it can be ignored.
Please see this description
penetration errors
