I am using a standing model with a solidworks nailer model imported using the solidworks2anybody feature. I am having a difficult time with the model view as the human model and nailer will not render. I get the following message when I try to bring up the model view:
[SIZE=1] ERROR(SYS1)[/SIZE] : Model View Draw : Unknown error
Model View failed to render scene.
[SIZE=2]Does anyone have a guess as to why this error keeps showing up and why I cannot view the model in model view?
The model is that of a human connected to a nailer. When I open the nailer (created in SolidWorks) by itself, usually the model view will work although occasionally the model will not render. Most of the minor parts always render but there is one sub assembly which also occasionally does not render in the model view.
The main model was working fine until I changed the velocity of one of the degrees of freedom and I thought changing it back would fix the problem but that hasn’t worked.
