I’m adding an atlanto-axial joint implant to the cervical spine in AnyBody. But it fails at the kinematic step, and the window shows the following information:
Failed to resolve kinematic constraints. Too many iterations used (final kin. error = 2.822234E+000).
Constraint no. #0 in ‘Main.HumanModel.BodyModel.Trunk.JointsCervicalSpine.C1C0Jnt.Constraints’ above error tolerance 0.000001, error = 0.001000.
Constraint no. #1 in ‘Main.HumanModel.BodyModel.Trunk.JointsCervicalSpine.C1C0Jnt.Constraints’ above error tolerance 0.000001, error = 0.004000.
Constraint no. #0 in ‘Main.HumanModel.BodyModel.Right.ShoulderArm.Mus.ArtificialRake.LinCombDrv’ above error tolerance 0.000001, error = 0.049550.
Constraint no. #1 in ‘Main.HumanModel.BodyModel.Right.ShoulderArm.Mus.ArtificialRake.LinCombDrv’ above error tolerance 0.000001, error = 0.295634.
Constraint no. #2 in ‘Main.HumanModel.BodyModel.Right.ShoulderArm.Mus.ArtificialRake.LinCombDrv’ above error tolerance 0.000001, error = 0.128179.
Constraint no. #0 in ‘Main.HumanModel.BodyModel.Right.ShoulderArm.Mus.ArtificialRake.LinCom2Drv’ above error tolerance 0.000001, error = 0.100000.
Constraint no. #1 in ‘Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.SCLinCon’ above error tolerance 0.000001, error = 0.003427.
Constraint no. #2 in ‘Main.HumanModel.BodyModel.Right.ShoulderArm.Jnt.SCLinCon’ above error tolerance 0.000001, error = 0.016070.
ERROR(OBJ.MCH.KIN3) : D:/P…s/A…y/A…2/AMMR/A…n/E…s/M…l/MaxForceNeckModel.main.any : Study.InitialConditions : Kinematic analysis failed in time step 0
How can I solve this problem?
Thank you in advance for your help!
