Hi AnyBody support,
I want to use the C3D file that I measured at Vicon.
But this error seems to appear.
ERROR(SCR.SCN6) : C:/U…s/t…f/D…p/a…y/A…5/A…n/my/G…)/EnvironmentAutoDetection.any : ‘PlateName’ : Unexpected character.
May I know the reason why?
I am using the AMMR version 1.5 and AMS version 5.3.
Regards
In your “EnvironmentAutoDetection.any” file you missed one thing:
ForcePlateType2AutoDetection Plate1 [b]([/b]
Hi Moonki,
Thank you for your reply.
The problem was solved.
ERROR(OBJ1) : C:/U…s/t…f/D…p/a…y/A…5/A…n/my/G…)/ModelSetup.any : C3DFileData.Points.Markers.RASI.PosInterpol : Parameter has an invalid value for this interpolation; extrapolations are not allowed.
Regards
Attached please find the modified version of your model.
The reason why you could see that kind of error is that there are many markers which are dropped-out in your C3D file.
So I had to adjust FrontFrameOffset and LastFrameOffset values in the ‘ModelSetup.any’ file to cut off some frames.
Also in order to run the MotionAndParameterOptimization process, I had to adjust the marker locations in the ModelSetup.any file.
And I tried to adjust the initial posture of the human model in the ‘TrialSpecificData.any’ file.
Hi Moonki,
I modified the file by the same method.
But I didn’t run the MotionAndParameterOptimization process.
ERROR(OBJ.MCH.KIN3) : C:/U…s/t…f/D…p/a…y/A…5/A…n/my/G…)/GaitFullBody.main.any : MotionOptimization.InitialConditions : Kinematic analysis failed in time step 0
Regards
Whenever you could see some problems in running your model, please upload your model in the ‘debug’ section:
