GaitApplication / GaitUniMiami
Hello guys,
It seems that the changes made to the gait application from version 1.4 up
“broke” the GaitUniMiami model.
Only version 1.3 is able to resolve the model position analysis.
Versions 1.4 and 1.7 give:
ERROR(82) : Failed to solve position analysis.
While version 1.6 gives:
ERROR(0) : System is kinematically indeterminate.
Which one is right? Is the GaitUniMiami wrong or is the GaitApplication 1.4+
wrong?
Thanks!
Jean-Olivier Racine, ing.jr
joracine@humancad.com
HumanCAD Development Team
NexGen Ergonomics Inc.
http://www.nexgenergo.com
(450) 621-0138
Hey Jean-Oliver,
You are right about the bug in version 1.4-1.6. It was a bug that I by mistake
introduced in the “old” gait model when I made a version that is compatible with
the new TLEM model. However, I thought I fixed it in version 1.7. It at least
worked on the dataset that I tested it on.
Could I ask you to upload your model to the filesection and I will take a look
at it?
Michael Skipper Andersen
The AnyBody Research Project
To: anyscript@yahoogroups.comFrom: joracine@humancad.comDate: Tue, 21 Oct 2008
09:55:55 -0400Subject: [AnyScript] GaitApplication / GaitUniMiami
Hello guys,It seems that the changes made to the gait application from version
1.4 up"broke" the GaitUniMiami model.Only version 1.3 is able to resolve the
model position analysis.Versions 1.4 and 1.7 give:ERROR(82) : Failed to solve
position analysis.While version 1.6 gives:ERROR(0) : System is kinematically
indeterminate.Which one is right? Is the GaitUniMiami wrong or is the
GaitApplication 1.4+wrong? Thanks!Jean-Olivier Racine,
ing.jrjoracine@humancad.comHumanCAD Development TeamNexGen Ergonomics
Inc.http://www.nexgenergo.com(450) 621-0138[Non-text portions of this message
have been removed]
News, entertainment and everything you care about at Live.com. Get it now!
http://www.live.com/getstarted.aspx
Hello Michael,
In fact, all I try to do is run version 1.7 off Gait Application 2 on the
UniMiamiModel from the repository version 7.0. So you can simply download
the repository, but I suspect you already have it.
(450) 621-0138
Of Michael Skipper Andersen
Sent: October-21-08 1:33 PM
Subject: RE: [AnyScript] GaitApplication / GaitUniMiami
Hey Jean-Oliver,
mistake introduced in the “old” gait model when I made a version that is
compatible with the new TLEM model. However, I thought I fixed it in version
1.7. It at least worked on the dataset that I tested it on.
look at it?
To: anyscript@yahoogroups.comFrom <mailto:anyscript%40yahoogroups.comFrom> :
joracine@humancad.comDate <mailto:joracine%40humancad.comDate> : Tue, 21 Oct
2008 09:55:55 -0400Subject: [AnyScript] GaitApplication / GaitUniMiami
version 1.4 up"broke" the GaitUniMiami model.Only version 1.3 is able to
resolve the model position analysis.Versions 1.4 and 1.7 give:ERROR(82) :
Failed to solve position analysis.While version 1.6 gives:ERROR(0) : System
is kinematically indeterminate.Which one is right? Is the GaitUniMiami wrong
or is the GaitApplication 1.4+wrong? Thanks!Jean-Olivier Racine,
<mailto:ing.jrjoracine%40humancad.comHumanCAD> Development TeamNexGen
Ergonomics Inc.http://www.nexgenergo.com(450) 621-0138[Non-text portions of
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.173 / Virus Database: 270.8.1/1734 - Release Date: 20/10/2008
7:25 AM
Hello Jean-Oliver Racine,
I looked back over my logs of changes and I think I know what the issue is but I
will need the support people to confirm this.
As far as I can see, the change that was made from version 1.3 to 1.4 was that
it was found that the scaling of pelvis was incorrect when using length mass fat
scaling both in the AnyBody model and in the hardcoded model inside
GaitApplication2 and this was what was changed from version 1.3 to 1.4. This
also means that the marker positons on pelvis would have to be changed.
I suspect that the GaitUniMiami model was made when the error was still there
and the optimisated motion is made using version 1.3. I am not sure if it was
ever re-run or not since I did not make this particular model.
Anyway, it should be possible to get it to work using the latest version of
GaitApplication2, but it probably needs a tiny little tweeking of the markers on
pelvis.I hope this helps.
To: anyscript@yahoogroups.comFrom: joracine@humancad.comDate: Thu, 23 Oct 2008
16:07:37 -0400Subject: RE: [AnyScript] GaitApplication / GaitUniMiami
Hello Michael,In fact, all I try to do is run version 1.7 off Gait Application 2
on theUniMiamiModel from the repository version 7.0. So you can simply
downloadthe repository, but I suspect you already have it.Thanks,Jean-Olivier
Racine, ing.jrjoracine@humancad.comHumanCAD Development TeamNexGen Ergonomics
Inc.http://www.nexgenergo.com(450) 621-0138From: anyscript@yahoogroups.com
[mailto:anyscript@yahoogroups.com] On BehalfOf Michael Skipper AndersenSent:
October-21-08 1:33 PMTo: anyscript@yahoogroups.comSubject: RE: [AnyScript]
GaitApplication / GaitUniMiamiHey Jean-Oliver,You are right about the bug in
version 1.4-1.6. It was a bug that I bymistake introduced in the “old” gait
model when I made a version that iscompatible with the new TLEM model. However,
I thought I fixed it in version1.7. It at least worked on the dataset that I
tested it on.Could I ask you to upload your model to the filesection and I will
take alook at it?Best regardsMichael Skipper AndersenThe AnyBody Research
ProjectTo: anyscript@yahoogroups.comFrom
<mailto:anyscript%40yahoogroups.comFrom> :joracine@humancad.comDate
<mailto:joracine%40humancad.comDate> : Tue, 21 Oct2008 09:55:55 -0400Subject:
[AnyScript] GaitApplication / GaitUniMiamiHello guys,It seems that the changes
made to the gait application fromversion 1.4 up"broke" the GaitUniMiami
model.Only version 1.3 is able toresolve the model position analysis.Versions
1.4 and 1.7 give:ERROR(82) :Failed to solve position analysis.While version 1.6
gives:ERROR(0) : Systemis kinematically indeterminate.Which one is right? Is the
GaitUniMiami wrongor is the GaitApplication 1.4+wrong? Thanks!Jean-Olivier
Racine,ing.jrjoracine@humancad.comHumanCAD<mailto:ing.jrjoracine%40humancad.comH
umanCAD> Development TeamNexGenErgonomics Inc.http://www.nexgenergo.com(450)
621-0138[Non-text portions ofthis message have been removed]
__________________________________________________________News, entertainment
nowhttp://www.live.com/getstarted.aspx[Non-text portions of this message have
been removed]No virus found in this incoming message.Checked by AVG -
http://www.avg.comVersion: 8.0.173 / Virus Database: 270.8.1/1734 - Release
Date: 20/10/20087:25 AM[Non-text portions of this message have been removed]
Invite your mail contacts to join your friends list with Windows Live Spaces.
It’s easy!
<a href=“http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us”>http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=
en-us</a>
Hello Michael,
Thanks for looking into it.
I’ll try to see if working with the values helps. Thanks for the pointers!
(450) 621-0138
Sent: November-01-08 9:17 PM
but I will need the support people to confirm this.
that it was found that the scaling of pelvis was incorrect when using length
mass fat scaling both in the AnyBody model and in the hardcoded model inside
there and the optimisated motion is made using version 1.3. I am not sure if
it was ever re-run or not since I did not make this particular model.
markers on pelvis.I hope this helps.
joracine@humancad.comDate <mailto:joracine%40humancad.comDate> : Thu, 23 Oct
2008 16:07:37 -0400Subject: RE: [AnyScript] GaitApplication / GaitUniMiami
Application 2 on theUniMiamiModel from the repository version 7.0. So you
can simply downloadthe repository, but I suspect you already have
it.Thanks,Jean-Olivier Racine, ing.jrjoracine@humancad.comHumanCAD
Ergonomics Inc.http://www.nexgenergo.com(450) 621-0138From:
anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
[mailto:anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> ] On
BehalfOf Michael Skipper AndersenSent: October-21-08 1:33 PMTo:
anyscript@yahoogroups.comSubject <mailto:anyscript%40yahoogroups.comSubject>
: RE: [AnyScript] GaitApplication / GaitUniMiamiHey Jean-Oliver,You are
right about the bug in version 1.4-1.6. It was a bug that I bymistake
introduced in the “old” gait model when I made a version that iscompatible
with the new TLEM model. However, I thought I fixed it in version1.7. It at
least worked on the dataset that I tested it on.Could I ask you to upload
your model to the filesection and I will take alook at it?Best
regardsMichael Skipper AndersenThe AnyBody Research ProjectTo:
<mailto:joracine%40humancad.comDate> <mailto:joracine%40humancad.comDate> :
Tue, 21 Oct2008 09:55:55 -0400Subject: [AnyScript] GaitApplication /
GaitUniMiamiHello guys,It seems that the changes made to the gait
application fromversion 1.4 up"broke" the GaitUniMiami model.Only version
1.3 is able toresolve the model position analysis.Versions 1.4 and 1.7
the GaitUniMiami wrongor is the GaitApplication 1.4+wrong?
Thanks!Jean-Olivier Racine,ing.jrjoracine@humancad.comHumanCAD
TeamNexGenErgonomics Inc.http://www.nexgenergo.com(450) 621-0138[Non-text
have been removed]No virus found in this incoming message.Checked by AVG -
Spaces. It’s easy!
<http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx
&mkt=en-us> &wx_url=/friends.aspx&mkt=en-us
Version: 8.0.175 / Virus Database: 270.8.5/1762 - Release Date: 02/11/2008
9:51 AM
Hi Jean-Oliver
Michael’s explanation sounds very likely, the repository was released April
25 and GaitApplication2 on May 8, so the GaitUniMiami has not been created
using ver. 1.4.
So please try to change the location of the markers on the pelvis slightly
this is could be the problem.
If it continues to cause problems please write again.
We will correct this in the next release of the repository.
Sent: 02 November 2008 02:17
To: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.comFrom> ps.comFrom:
joracine@humancad. <mailto:joracine%40humancad.comDate> comDate: Thu, 23 Oct
<mailto:ing.jrjoracine%40humancad.comHumanCAD> humancad.comHumanCAD
Development TeamNexGen Ergonomics Inc.http://www.
<Inc.http://www.nexgenergo.com> nexgenergo.com(450) 621-0138From:
anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com> ps.com
anyscript@yahoogrou <mailto:anyscript%40yahoogroups.comSubject>
ps.comSubject: RE: [AnyScript] GaitApplication / GaitUniMiamiHey
Jean-Oliver,You are right about the bug in version 1.4-1.6. It was a bug
that I bymistake introduced in the “old” gait model when I made a version
that iscompatible with the new TLEM model. However, I thought I fixed it in
version1.7. It at least worked on the dataset that I tested it on.Could I
ask you to upload your model to the filesection and I will take alook at
it?Best regardsMichael Skipper AndersenThe AnyBody Research ProjectTo:
-0400Subject: [AnyScript] GaitApplication / GaitUniMiamiHello guys,It seems
that the changes made to the gait application fromversion 1.4 up"broke" the
GaitUniMiami model.Only version 1.3 is able toresolve the model position
analysis.Versions 1.4 and 1.7 give:ERROR(82) :Failed to solve position
analysis.While version 1.6 gives:ERROR(0) : Systemis kinematically
indeterminate.Which one is right? Is the GaitUniMiami wrongor is the
GaitApplication 1.4+wrong? Thanks!Jean-Olivier Racine,ing.jrjoracine@
humancad.comHumanCAD<mailto:ing.jrjoracine%40humancad.comHumanCAD>
<Inc.http://www.nexgenergo.com> nexgenergo.com(450) 621-0138[Non-text
nowhttp://www.live. <http://www.live.com/getstarted.aspx>
com/getstarted.aspx[Non-text portions of this message have been removed]No
virus found in this incoming message.Checked by AVG - http://www.avg.
<http://www.avg.comVersion:> comVersion: 8.0.173 / Virus Database:
270.8.1/1734 - Release Date: 20/10/20087:25 AM[Non-text portions of this
Spaces. It’s easy!
http://spaces.
&mkt=en-us>
