Hello All
I have also the same problem I have a macro file and I want to import it to AnyBodyCon.exe
but when I type “AnyBodyCon.exe\m mymacro.anymcr”
it generate the error : commandexpected !!
Please help me . I have read all of the posts related to those people who had the same problem but I finally did not understand how to import a macro in to anybodycon !!!
anither thing , My “AnyBodyCon.exe” and “mymacro” file are in the same folder
The problem is that “AnyBodyCon” is not a valid command for it
How to fix it ?
Many thanks for your help
when i want to run a AnyBody batch job, i change the directory (cd) to the folder which contains the …Main.any. I place the batch.anymcr in this folder as well. And i start the analysis with the full path to the executable:
c:\Programs\AnyBody Technology\AnyBody.5.3\AnyBodyCon.exe" /m batch.anymcr
Hi Thomaz
I did the same job
my Main file and Macro file is exactly in the same folder with AnyBodyCon.exe
I have not change or copy AnyBodyCon.exe
and I type C:\Program Files\AnyBody Technology\AnyBody.5.2\m mymacro.anymcr
and it again says : error : command expected !!!
even when i type AnyBodyCon.exe/? or AnyBodyCon.exe?
again it generate the same error
Addittionally , I read the tutorial which say that coomands that can be used in console including :load run exit ,…
but nothing has been said about AnyBodyCon.exe as a command
Have you been careful when copying the commands?
I miss the “exe” (but this could be all right) and a blank between the command and “/m”
If this is still not working, what does your macro contain?
You could also try to put the whole command in inverted commas, like
