Weightlifting Movement
On this link you can find an example of snatch (weightlifting) that
I should simulate with Anybody Modeling System.
http://www.qwa.org/natrecvideo/CONTENT.ASP
This movement foresees that the initial position of my skeleton
is:
flexion of the knees 100 degrees,
flexion trunk 30/40 degrees,
flexion ankles 70 degrees,
fixed heel to the ground.
From this position the skeleton in the time is stretched completely
in iper extension and then it is set in squat position.
Can you help me to complete it?
Thanks
Raffaella
